WT-Parts Problem
cscholl
WT-Parts Problem
Hello PTC Community ,
I`m working with the WT-Parts-Structure in Windchill. In our system the CAD-Documents are allready existing. I`m meanwhile able to create WT-Parts through "auto associate".
When I open the WT-Part-Structure through the function "show/hide" -> "CAD-Documents" all Referencedocuments appear e.g. the .prt-drawing and the .asm-drawing.
If I have for example a standard part and I create the associated WT-Part the Part-Structure also shows all the Assembly-Drawings where the standard part is used.
But I only want to see the .prt and the .drw-model of the standard part.
Are there any settings or filter options that I can use? Or is there already a mistake in creating the WT-Parts?
Thanking you in anticipation
MikeLockwood
22-Sapphire I
(To:cscholl)
This might be the preference which controls but not sure.  The "Calculated Links" likely is the key thing to prevent.
"Disallow Product Structure Links by Document Types"
Where can I find the function "Disallow Product Structure Links by Document Types"?  Can I find it in "My settings" -> "settings"?
MikeLockwood
22-Sapphire I
(To:cscholl)
Yes, a preference.  Under Operation, Auto Associate.  May be able to change from My Settings to test.
Ok, then I have to contact our system administration to change the settings.
Thank you very much.
