WTPARTUASGAELINK Migration
akshay_r
6-Contributor
I'm Trying to migrate Non Windchill source Part to Windchill WT-Part, while trying to load the usage link Found out this
bit confused which one to use to migrate the links, I know that EPM and WT-Part has Usage Link.
While stagging wbmldr tries to check all the above-mentioned tables.
HelesicPetr
(To:akshay_r)
Hi @akshay_r
From your description there is no information what is the problem?
Any error from a log? method server log what ever.
There are several articles describes some troubles with migration and wbmldr command.
CS416422 - Error encountered when using "wbmldr -s WTPart" command in Windchill Bulk Migrator
CS394993 - "wbmldr -r wtpartusagelink" fails in Windchill Bulk Migrator
PetrH
akshay_r
6-Contributor
(To:HelesicPetr)
Problem was i was confused which table need to be used for populating the WTPARTUSAGELINK there are multiple tables in the stagging database.
HelesicPetr
(To:akshay_r)
Hi @akshay_r
The WTPART means that it is usage link for a WTPart type
for the EPMDocument there is a different usage type wt.epm.structure.EPMMemberLink
PS>there can be an another link type between the EPMDocument and WTPart and it is usually EPMBuildRule link.
PetrH
akshay_r
6-Contributor
(To:HelesicPetr)
Hi @HelesicPetr
Why there is multiple tables for WTPARTUsageLink
I found these table for WT-Part on this which one needs to be used, is there some explanation for the table names with number?
(eg:)WTPARTUSAGELINK__808787902 why this tables are mentioned with number.
Does WTPARTUSAGELINK__XXXXXXXX , the number has any specific representation on links
HelesicPetr
(To:akshay_r)
Who knows 😄 You could try to migrate the data several times and it is linked with each try.
Try to clean up the stage database before next try.
Also I would advice try to open a case with PTC support for a help with the data balk migration.
PetrH
