We are running Partslink 10.2 M020 CSP18. When I go to create a new WTPart it is adding the classification step before I ever select how to classify the item. Has anyone come across this issue and fixed it. This is a brand new install.
I had a similar issue occur. Called PTC TS and worked with a tech. The solution for my issue ended up being exporting the current classification schema tree and re-importing it, overwriting the schema with itself.
Thanks for the info. I have a call open with PTC and we will see what they come back with but wanted to work this from both ends. If they don't come back soon with anything I will give this a try.
