WTPart softtype lifecycle
VasiliyRepecki
Hi.
I have a problem with WTPart softtype lifecycle.
I've created softtype of WTPart and specified lifecycle for it. And l've imported customized OIR also.
If softtype instance is created through windchill interface - it has lifecycle defined by me.
If i create softtype instance by java code - it has standard lifecycle.
Can anyone help?
Thanks.
KD
(To:VasiliyRepecki)
At the time of creating softtype instance by java code you can also set lifecycle using LifecycleHelper.setstate method.
The OIR is not invoking when you are craeting it through code.
Kaushik
