I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.2
WTPart with default unit value as Inch can't be edited, system says Required Information Is Missing. WTPart with other Default units works fine.
Here are the errors that I faced
Required Information Is Missing in the EDIT part screen.
Are you sure this has only to do with the default unit of measure? Seems like it should be pointing to something else. Were you using multi-part edit screen?
We are getting this error in single EDIT screen.
Can you post a screen shot of all the edit tabs?
Hello VP_92528801,
Is there any customization in this Windchill instance? did you try ootb?
Can you share MethodServer log? and a screenshot of the error from the UI?
KR,
Charles.
If the problem is limited to just this UOM, perhaps there something off in your Resource Bundle for units. If it works for other parts but not this one, then perhaps there must be something different with this part. E.G. It may have a distribution target associated to it that is preventing the UOM edit.
what error you see in logs
