WVS Config Spec.
TomU
WVS Config Spec.
Where does one set the config spec. used by WVS when publishing on check in? I am attempting to configure Creo drawings to publish "as stored" and all other Creo objects to publish "latest".
The documentation states the following:
The config spec that is used for the publishing process, is provided by the application that emits the event, for example, a WGM. If that config spec is "null," WVS uses either the latest config spec or an as-stored config spec depending on the value of the property "publish.configspec.default.useasstoredifavailable."
Where is the config spec set for the Creo workgroup manager?
Thanks!
Tom U.
arajagopal
11-Garnet
(To:TomU)
Let me know this link can answer your question.
I don't have experience using this propertypublish.configspec.useworkspaceconfigspecforpublish, but looks like this setting giving two options. True - As Stored, false means Latest config spoec.
I don't see any documentation on another propertyThanks
