Want to copy a WTPart structure and only inlcude specific WTParts in the new structure
MichaelSchumach
We want to create an overloaded master BOM for our top-level machines and then have the user make a copy of the master BOM and only include the specific WTParts needed to create the new machine structure.
Overloaded BOM WTPart example for windchill
lvl0 5-BAR820-MASTER-BOM
lvl1 5-G13071 (group of different steel frames to select from)
lvl2  5-27926
lvl2  5-26113
lvl2  5-21341
lvl2  5-10893
lvl1 5-G13076 (group of different control panels to select)
lvl2  5-27808
lvl2  5-27807
In the example above, I want my user to copy the 5-BAR820-MASTER-BOM and give it a new name (for example, 5-BAR820-SN1000) and then either include or exclude the LVL1 and LVL2 WTParts as needed to create the new machine.   I rename the top-level to 5-BAR820-SN1000 and then  select the existing WTParts to include and I have a new WTPart structure as shown below.
lvl0 5-BAR820-SN1000
lvl2  5-26113
lvl2  5-27807
I have tried the 'save as' but when I show the dependents in the 'save as' window, I am asked for new names for each WTPart in the structure.   The only name that is changing is the top-level WTPart.
Anyone with recommendations how this can be done?   Best practices?  The steps that I should be taking to make this work?
Thanks for any insights.
Mike Schumacher
Use OOTB Options and Variant module to create your variant BOMs.  Once setup (takes some work) you'll have a robust  system for creating variants of a machine....as a PLUS the user that is creating the variant will only have to answer some simple questions to get a complicated BOM.
Mike - there are two possibilities
1 - Re-identify the intermediate assemblies as the definition is varying.  You can not reuse the same part number but say it is different in this case.  eg lvl1 5-G13071 & lvl1 5-G13076 become lvl1 5-G13071_sn1000 & lvl1 5-G13076_sn1000
2 - Use a configurable methodology (options and variants).  In this case the top and intermediate nodes would be configurable and you would be creating lvl0 5-BAR820-SN1000 as a variant based upon selecting the appropriate selected modules under lvl1 5-G13071 & lvl1 5-G13076 .  You can find more information on this here:  https://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=OptionsManagProdConfigOview&action=show‌.  The powersystem demo dataset is an example you could kick the tires on.
