Watermark rev of wt.part on the published drawing
Dmi3U
I am hoping somebody already figured it out, and it is not a costly customization...
now we are watermarking only State and Last modified on pdf published drawings. We got a request to stamp a rev on the drw and since the rev of the drw can be different from rev of the wt.part, we need to stamp rev of the wt.part.on the published pdf.
Any help will be greatly appreciated!
Have to add: we are on WC10.1 m040, CreoPro2.0 m050
Hello
The problem is that CreoView does not load the same attributes depending from where you open the Viz and how you link the drawing to the WTPart
-If you open the drawing from the drawing info page, you will not have the WTpart attributes. So impossible to use it for watermarking
-If you open the drawing from the WTpart info page AND if you explicetly associate the drawing to the WTpart, you will have the wtpart rev parameter in Creo View. So possible to use it in watermark
Another way, is to customize the Delegate , Describe in the Proe and Widnchill Guide, to get the WTpart number, rev etc ... as system parameter in the CAD prt, drw ... so able to use them in watermarking . whatever is the context of Viz
regards
