I am using Windchill ProjectLink Release 10.2 and Datecode with CPS F000
We are planning for Windchill Upgrade from WC10.2 to WC12.
We have customization on custom Wizard. I would like to understand how to port it to Windchill 12
If its a wizard, it will not impact the upgrade process at all. You can fold in your customizations at any point you like. Remember that you will likely be doing a double hop upgrade. I recommend going to 13 not stopping at 12. The target system is just a straight up install. The upgrade process mainly impacts the database and some configuration.
Hi @VM_10064149
The customization transfer is not so complicated. you have to just know how the customization has been written.
usually you transfer following type of files and configuration>
class files
jsp files
mvc definition
xconf definition
service definition
customAction definition
customModelDefinition
I would say, that if you use Apache logging you have to update your code to include new apache logging package.
org.apache.logging.log4j
also there are some API changes that you have to confirm that all your customization could work.
PettrH
Hi @VM_10064149,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
