We need to place "new view" action under Actions menue directelly
aida
The"new view" action should be under Actions menue directelly and not Under the sbmenu Actions\menue.
So, this action does not create a very new object.
However, the action new version create realy a new object is Under menue Action.
The action  semantics  does not respect the actions a classification.
So we propose to change this action Under Actions menue.
STEVEG
(To:aida)
Should this be moved to the Windchill Ideas forum?
Hi @aida,
You can achieve this by following below steps.
1. Open "<WT_HOME>\codebase\config\actions\PartClient-actionmodels.xml" file
2. Locate below line under "more parts toolbar actions new" model:
<action name="newViewVersion" type="part"/>
3. Comment out this line
4. Add same line under "more parts actions" model
5. Save this file.
6. As a Windchill Administrator access below URL:
http://<WC_Host>/Windchill/app/#ptc1/carambola/tools/list
7. Click Reload Action(s)
8. Navigate to Folder page and you will observe that New View Version is now available under Actions menu.
Note: Above steps are just for your illustration purpose, make sure you follow Best Customization Practices to avoid maintanance update override.
Best Regards,
Shirish
