We want to run Windchill with IIS and Windows Integrated Authentication enabled.
AndyMiner
3-Newcomer
Hi All,
We are just starting to create a development platform for Windchill on a Windows 2003 64 bit VM. We would like to run IIS and have single signon with Windows Integrated Authentication (if that makes sense). The Advanced configuration guide outlines steps for basic auth with integrated authentication disabled. Are there configurations with integrated authentication enabled? Obviously, I'm new to this and any configuration guidance would be appreciated.
Did you get any update on this? Sad to do not see any response after 11 years 😞
TomU
(To:WV_10110649)
It looks like single sign-on with IIS is not officially supported, so you're probably on your own.
https://www.ptc.com/en/support/article/cs358524
i am not aware of any plans or communication from ptc to support windchill on iis
TomU
(To:ScottMorris)
Windchill has been supported on IIS for quite a long time.  No idea about single sign on though...
From the Windchill 12.0 support matrix:
ScottMorris
(To:TomU)
@TomU thank you for the correction!
