WfPropagationQueue is deleted Mistakenly
JohnDavid
7-Bedrock
Hi all,
Today morning i deleted mistakenly WfPropagationQueue from Queuemanager of PDMLink system instead of deleting the queue entries.
how can i restore this?
Now i could not even start windhill..
Thanks in advance for your reply.
BR,
John D.
Interested in what the fix turns out to be. I almost did this twice in the past.
Seems that PTC should make you say Yes, I really, really want to delete this queue with about 10 confirmations, rather than making it so easy.
Have you tried restarting Windchill - most if not all queues will get re-created at start time?
Yes. But i even could not make the system up...
It was throwing some workflow error..
System was up when we did the following setting
wt.queue.max.processQueues to value 100.
Now the queues are recreated.:)
Yeah - I think that you had hit the maximum number of allowed queues and so Windchill could not recreate the WfPropagationQueue at start time, hence the need to increase the wt.queue.max.processQueues which would then allow the queue to be created at start..
