Version: Windchill 12.0
Use Case: WfPropagationQueue severe entries.
Description:
I am working as an Admin. i see there are 10000+ severe/failed entries in the WfPropagationQueue.
is this concerning? what should be the normal value and how to keep the Queues healthy? please help me understand if any procedure i need to follow. see snap attached.
Release: 12.0.2.7
thanks
Sandeep
severe and failed entries can be deleted with no concern they will be recreated , as you have +10000 entries , you may use the utility to reset them in bulk : https://www.ptc.com/en/support/article/CS134506
Hi @Fadel ,
thanks for your response. i see an option here to reset them see snap Queue_1.jpg
i have reset the Queues from there but still the number didn't reduced.
Br,
Sandeep
Thanks , I see now that the entries are in ready state , however it seems there is an issue with argument :
try to run the tool again and this time delete entries instead of reset .
hi @Fadel ,
the entries are failed again. is it okay if i delete them ? will there be any issue or anything i need to check before deleting them?
Br,
Sandeep
you can delete , any entry needed will be recreated
