What is the best practice for mass update state from INWORK to RELEASED of parts/doc belonging to an assembly?
M.RehanYousufQu
What best practice one should do for mass update state from INWORK to RELEASED of parts/doc belonging to an assembly?
I see many options and looking at the different UI pages came up with the following: Appreciate feedback in this regard.
UI Page
Check-Out State
How to start
Multiple Objects
Dependencies
Access for Set State permission
Detail Page
Must be checked in
Action menu
N/A
No collector
Yes
Folder View
Must be checked in
Add to Workspace / Action menu / New promotion request
Yes for editing multiple object but No for doing set state on multiple objects.
Objects must be associated or dependent part/doc
Yes
Product Structure Browser
Must be checked in
N/A
No collector
Yes
Search Results
N/A
Add to Workspace
N/A
No collector
Yes
New Promotion Request
Must be checked in
Action menu
No
Yes
Lifecycle
/ Workflow
Must be checked in
Lifecycle based
N/A
No collector in UI but can collect related part/doc programmatically
Yes
Revise
Must be checked in
Action menu
No
Yes
- Rehan
Hi Rehan,
Excellent job in summing up some of the methods.
There is another method that may work for you. In some of the later maintenance releases we have added a utility that can perform these updates.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS13365
See the Windchill Online help section entitled "Running the Life Cycle Template Command Line Utility" for more information on its use
Good Luck,
Jarrett
