What best practice one should do for mass update state from INWORK to RELEASED of parts/doc belonging to an assembly?
I see many options and looking at the different UI pages came up with the following: Appreciate feedback in this regard.
UI Page | Check-Out State | How to start | Multiple Objects | Dependencies | Access for Set State permission |
Detail Page | Must be checked in | Action menu | N/A | No collector | Yes |
Folder View | Must be checked in | Add to Workspace / Action menu / New promotion request | Yes for editing multiple object but No for doing set state on multiple objects. | Objects must be associated or dependent part/doc | Yes |
Product Structure Browser | Must be checked in | Add to Workspace / Action menu / New promotion request | N/A | No collector | Yes |
Search Results | N/A | Add to Workspace | N/A | No collector | Yes |
New Promotion Request | Must be checked in | Action menu | No | Objects must be associated or dependent part/doc | Yes |
Lifecycle / Workflow | Must be checked in | Lifecycle based | N/A | No collector in UI but can collect related part/doc programmatically | Yes |
Revise | Must be checked in | Action menu | No | Objects must be associated or dependent part/doc | Yes |
- Rehan
Hi Rehan,
Excellent job in summing up some of the methods.
There is another method that may work for you. In some of the later maintenance releases we have added a utility that can perform these updates.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS13365
See the Windchill Online help section entitled "Running the Life Cycle Template Command Line Utility" for more information on its use
Good Luck,
Jarrett
