What is the difference between master vault, replica vault and cache vault?
SOLVED
Re: What is the difference between master vault, replica vault and cache vault?
You would have to run a revaulting process to move the data to whichever vault you want to keep.  Full instructions are available here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS124088
Hi Tom,
Thank you very very much for your precious time and response. It was very nice discussion.
It worked for me
Thank you
Sumit Patil
Hi Ben,
Thank you very much for your response, Now it worked for me. Thank you for this great discussion.
Thank you
Sumit Patil
We have set the property useVaultsforAllContent as true and configured only one Master Vault till now.
When the data is uploaded first it get loaded in Cache vault and then sync to the Master vault through synchronization.
But its Copy process and not move , is it the Ideal scenario or we have to set any property for the Move as its duplicate.
To save budget instead of local disks, you can use:
 Yes the storage is one perspective.
But why the data is present in both the cache vault & Master vault with the same file name.
Is the Windchill moves the data or copy in my scenario I observe copy process but not all files are present in the both the location.
Could you explain the process?
