When a user tries to update his workspace he gets the following error: K03_UWGM_ACTION_NAME_MODIFYFORPRIVATE...never saw this one before.
What version/build, etc.
Windchill: 10.2 M030-CPS12
Creo: 3.0 M050
I had today a similar one:
Workspace Synchronization cannot be performed due to the conflict in File Name '<xxxxxxx_flat.prt>'
Workspace Refresh Failed in Action 'K03_UWGM_ACTION_NAME_UPLOAD'.
I've definitely seen this before, but can't find anything about it. Strange.
A user in our company received a similar error today that I have never seen before, trying to figure out what is going on.
Workspace Refresh Failed in Action 'K03_UWGM_ACTION_NAME_ADD'.
One of my users that I support also got the error : "Workspace Refresh Failed in Action 'K03_UWGM_ACTION_NAME_ADD'."
It seems as if the workspace somehow became corrupt and communication between Server and client-side workspaces somehow was affected.
The only way we could get it to work, was by deleting the workspace cache on the clients-side, and rebuilding it.
just experiencing the same with one user, getting this error message when trying "Add to workspace"
However, the objects (wtPart, cad models & assemblies & drawings) are found in the context root/default workspace, not the active one which was the target.
So, did you clear all caches on the Workstation in question and deleted the folder structure? That's it?
In our case there was more error messages. All happened in a Project context where a generic was not shared to the Project, only instances. This is described here:
https://www.ptc.com/en/support/article?n=CS15693
Confusing symptons (once the adding to workspace without generic being shared fails ANY cad add to workspace fail..) with this one and the error message referring to master reference in EPMDocument and EPMDocumentMaster don't make the troubleshooting straight forward...
one user had the same error while adding objects to workspace. (WC10.2 M030)
Tried adding from Standalone browser. it worked fine. when he did add to workspace in Creo session, he had the below error.
Then again we removed from workspace and tried adding in creo embedded browser. it is working fine.
Don't know why this error occurs
