What's New In Windchill 10.2 M010-M030 for Document Management
sm
PTC has been presenting what's new in Windchill 10.2 Document Management since last year's PTC Live Global event. Attached is a presentation that covers what's new in the active and coming maintenance releases; M010-M030. Hopefully you'll find some cool and exciting capabilites in the latest releases.
As a pre-emptive answer, no browser drag-n-drop features are supported in any version of Internet Explorer in WIndchill 10.2. PTC is avtively working on this and plans to fully support "Edge" mode for the newer versions of IE with HTML5 capabilities in Windchill 10.3.
33 REPLIES 33
Gagan
(To:sm)
Very Nice Document Scott , thanks a lot for sharing
mzerle
11-Garnet
(To:sm)
Thank you for the document! Question about the Outlook-integration: Will 11.0 support the creation of further objects, like Problem Report/Change Request? Would be very helpful to enhance the functionality. Same like replacing content directly from outlook. Will be also "Email Document" on multiple documents enabled?
sm
(To:mzerle)
Right now there are no plans to support change objects in the DTI Outlook Integration. Its a good idea, so it should be created as a new Windchill Product Idea. I really like your idea around emailing multiple documents. That is not in the backlog now, but probably should be. Can you also create a new Windchill Product Idea for that? The Ideas get a bit more visibility and are reviewed periodically to prioritization and consideration.
mzerle
11-Garnet
(To:sm)
