When accessing the Windchill URL "http://<Hostname>/Windchill/app", getting an error
BRAHIM
11-Garnet
I am facing an issue in PTC Windchill 12 when accessing the Windchill PDMLink application. The URL http://<Hostname>/Windchill/app returns an error,  "The requested resource [/Windchill/app] is not available."
The problem is caused by not using a trailing "/" after
Windchill/app in the URL. While the workaround is to use http://<hostname>/Windchill, which appends the trailing '/' automatically,
I need a permanent solution. I am looking for a way to configure the server or modify settings so that http://<Hostname>/Windchill/app works correctly without manual adjustments.
avillanueva
23-Emerald I
(To:BRAHIM)
I think this is a webserver configuration. In my proxy, I have a line that uppercases Windchill. I think this can work for you to add the slash.
RedirectMatch ^/windchill$ https://<hostname>/Windchill/
avillanueva
23-Emerald I
(To:BRAHIM)
