Hello To All,
When you are checking in a drawing and it is giving you an error that says drawing if not unique?
Thanks Billy
Either a drawing with that name is already in Windchill or you changed the 'number' of both the drawing and the model to be the same. The Common name can be the same and the filename is automatically different, but the numbers need to be different.
