Is there a way to search all structures/assemblies in Windchill to see where both Part A and Part B are used?
Where used only take a single part as input.
I would like a Where Used that can take multiple parts as inputs.
Hi @VL_10308942,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
I assume that when you refer that "Where Used" takes only one input, you meant that in the UI.
If so, I think its the OOTB intention.
However if you want to see where used for more than 1, I suggest you use Reporting functionality.
Cheers
Hari
I made a simple report for you to take it from here.
I got the below output
Cheers
Hari
I will try it. Thanks.
Hi @VL_10308942,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
