Where to write the code?
SOLVED
Re: Where to write the code?
I can't read Cyrillic (assuming it is Cyrillic), but what you have under Current Processes: are the two processes you should be modifying. The Life Cycle State for Promotion is the state user picks when promoting the object, and the workflows are the two options. You have another Preference for All states, and therefore it might be the one more applicable to your case, not the Test18 In Analysis one that you have highlighted, unless you are testing those workflows only.
yadavankur, thank you, the right template was found, but now there is a problem with the code. Tell me, please, what type should have a variable obj ? I've tried every type I know, but I haven't passed the test
Checking Syntax...
warning: Supported source version 'RELEASE_7' from annotation processor 'com.microsoft.azure.management.apigeneration.LangDefinitionProcessor' less than -source '1.8'
WfExpression_11.java:54: error: cannot find symbol
obj = results.nextElement();
symbol: variable obj
WfExpression_11.java:55: error: cannot find symbol
if (obj instanceof wt.doc.WTDocument)
WfExpression_11.java:57: error: cannot find symbol
var += obj.getName ()+","; // var is a global variable
Note: WfExpression_11.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
3 errors
1 warning
Syntax check complete.
Try wt.fc.Persistable:
wt.fc.Persistable obj = results.nextElement();
zsternal-2, thanks for your suggestion, but it still didn't work out (
Checking Syntax...
WfExpression_11.java:57: error: incompatible types: Object cannot be converted to Persistable
1 error
1 warning
Okay! Try using Object then:
Object obj = results.nextElement();
And if that doesn't work use java.lang.Object.
zsternal-2, tried, but the result is the same
