I am currently testing Windchill 10.1 and getting ready for implementation. I wanted to know which browser I should use to work best with Windchill 10.1 and Java.
I use Chrome for everything but I was not sure if IE or Firefox had any advantage with Java running smoother.
ΜΟΛΩΝ ΛΑΒΕ
Current version of the file is dated in June 2015:
http://www.ptc.com/WCMS/files/125513/en/WindchillWebBrowserComparisonTechBrief.pdf
I do appreciate the link to the document but it's so old, I can't use it to make a decision. I will stick with IE10 for now, but I was running it on Firefox and Chrome just fine.
ΜΟΛΩΝ ΛΑΒΕ
Damian,
We just finished our own testing with Windchill 10.1 M030. Internet Explorer 10 does not work. It constantly crashes making things difficult to say the least. We are currently using FireFox, as this was the most stable and crash free.
Hope this helps.
Brian
I use Chrome for Windchill 10-10.1. If I'm having to go back to WC 9, I'll use IE. I can't recall having a problem with any features using Chrome/WC10.
That being said, I still keep multiple browsers installed just in case. You can always switch to IE, FF if you find certain features do not work as well. I find it to be good practice on any web applications.
In Reply to Brian Clark:
Damian,
Hope this helps.
Brian
Are you using the following config command?
windows_browser_type mozilla_based_browser
I figured if you are having issues with IE that the internal browser which uses the IE Engine may give you problems as well or is this different?
Can I keep the internal browser in Creo as IE but use Firefox as the stand alone browser?
I prefer Chrome and may choose this as my stand alone option.
ΜΟΛΩΝ ΛΑΒΕ
We're on 10.1. Our users generally have the capability of choose which browser to use. I've seen no isues on IE9 and FF. Several use Chrome, I didn't hear of any problems until they tried to launch Creo View.
In Reply to Damian Castillo:
ΜΟΛΩΝ ΛΑΒΕ
Hi
I would first check what your company IT policy is. Can any user install any webbrowser ?
Could you have other systems requiring a particular version of a particular webbrowser ?
As said above by someone else. ProductView is not always compatible with other webbrowsers.
Is the fact that Chrome display certain pages more quickly than IE a good enough reason when certain functionality (maybe not often use) will not work with Chrome.
Personnally, I use Chrome only for certain tasks but I know the risk I take, sometimes windows get frozen and I tend to clear Chrome's cache a lot more often than with IE.
We don't restrict users from what Browser they can run or from installing applications on their workstations.
I simply want to know which browser is best for Windchill 10.1 so that I can let all my Engineers know which one to use.
I also wanted to know about the embeded Creo browser. My understanding is that it uses the IE engine. Is it OK to leave this default broswer alone? My users will mainly access Windchill through the embeded browser anyway.
ΜΟΛΩΝ ΛΑΒΕ
Albert,
Thank you for the straight forward response on this. I think we will go with Firefox for the stand alone option since our VAR also used it when they conducted our training and I will just keep the default IE option for the embedded browser in Creo.
Let's see how this works for us.
Thanks again
ΜΟΛΩΝ ΛΑΒΕ
Hi there,
We are currently on PDM 10.1 M040, and force the use of I.E 10. There is a second part to this, you also have to consider your Java version; in this configuration we've had to hold everyone to Java 7.51.
I have directly seen problems with using Chrome at least when it comes to file editing. Our most notorious (and somewhat hilarious) example; in Chrome, when creating a new Document object type I've seen it create that Document...and 450 duplicates. Simultaneously. That took me a while to clean up
. And our other IT members have mentioned various general problems with Firefox including its memory usage, so we didn't bother with it either.
So IE 10 for us.
We are on PDMLink 10.1 M050. We are starting to use IE 11 more and more. It is supported by PTC on this version and build but I don't know off-hand about previous builds. We also are currently on 2 different versions of Java. Version 6 Update 38 or version 7 Update 76. They both work. We started out with 6 U38 for everyone when we went to 10.1 M040. Then since we went to M050 I did some testing of several different Java versions and decided on 7 U76. The only thing with 7 is it displays a dialog box asking you to Run or Updated. Annoying but manageable. On the upside I was having problems with showing the workflow in the template administration. It would work on the icons the first or second time you try to open one but after that it wouldn't. Java 7 fixed that for us.
