Hi All,
I am using Creo 3.0 M070 version with Windchill 10.2 M030.
First time it was checked in successfully, and it's iteration is A.1, next time when i checked it out and do some modification, and then again try to check - in, i am getting below error in Event manager.
Content category "" for content object "sample.prt" in the document "sample.prt" could not be found on server.
is any one face this issue ? any possible solution for this ?
Vivek
Vivek,
As this question is related to Windchill, moved the post to Windchill community.
Are you on the master server or on a replica server?
Can you search in Windchill and find it?
