Why PTC decided to not enable these features also on 10.2 version?
SOLVED
Re: Why PTC decided to not enable these features also on 10.2 version?
This is the last update I got from TS:
Hello Marco,
Yes, she (Lori) is asking for double-check of the status in fact.
This is what I will do with the R&D. I will gather some more details and see if it can be backported in 10.2 M030.
However, I cannot guarantee anything as some customers already asked for a backport but it was not possible.
I will check and let you know the result beginning next week.
Best regards,
  1. Karim.
Marco
This is the good news just arrived from TS:
Some good news to provide at the moment. After some analysis and discussion, the R&D agreed to backport the fix to 10.2 M030.
For the moment the target is 10.2 M030 CPS20.
I will keep you informed in case there are any changes in the plan.
Marco
Today TS published some news about my second request (Latest versions of views with Alternate BOMs are not found with a "Search").
Issue will be fixed with CPS20 scheduled in November (see below article)
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS202411
Thanks again to Karim of TS.
I will mark this discussion as answered after testing CPS20 next month.
Marco
Hi
lot of lobbying also from our side for this backport   🙂
Thanks also to Serge and Mario from PTC TS
waiting the CPS to test the effective solution,  cause during exchange with R&D and QA , they give an example of search result
in the yellow table.
Seems to be a Typo in the spec, cause I ask to have the second result in green
wait and see
Hi Gregory,
the unity is strength, so thanks also to you.
Marco
I think PTC should listen more often to their community! There are already a lot of very interesting ideas and concepts here. So let's push it further!
I have just installed CPS20 on our test server and also verified that issue has finally solved.
Marco
