WinDU is failing for the following tasks on Windchill PDMlink 10.2 M030 installed on Linux system.
-Verifies the Internet Domain
-Invalid Ldap Entries
Could you please let me know how to resolve these issues.
VerifySourceInternetDomain.log
Error in method server code:
java.lang.Exception: Exception of type 'java.lang.reflect.InvocationTargetException' was generated on the server with message 'null'
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.ptc.windchill.upgrade.updates.directives.MigratorMethod.invoke(MigratorMethod.java:131)
at com.ptc.windchill.upgrade.updates.directives.LightWeightServiceDirective$Server.invokeLightWeightServiceApi(LightWeightServiceDirective.java:635)
at sun.reflect.GeneratedMethodAccessor1025.invoke(null)
at wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:152)
at wt.method.MethodResult.writeExternal(MethodResult.java:226)
at java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1455)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1429)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1177)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:347)
at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:293)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:332)
at sun.rmi.transport.Transport$1.run(Transport.java:177)
at sun.rmi.transport.Transport$1.run(Transport.java:174)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:173)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:556)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:811)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:670)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Task failed.
com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate Verifies the Internet Domain (#VerifySourceInternetDomain)
Nested exception is: (com.ptc.windchill.upgrade.updates.directives.directivesResource/39) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Method server code wt.org.VerifySourceInternetDomain.runDiagnosticTask failed. See nested exception for details
Nested exception is: wt.util.WTException: wt.method.MethodResultException: *ERROR* Server side Exception has occured: See MethodServer log for details
Nested exception is: wt.method.MethodResultException: *ERROR* Server side Exception has occured: See MethodServer log for details
at com.ptc.windchill.upgrade.updates.directives.LightWeightServiceDirective$Server.invokeLightWeightServiceApi(LightWeightServiceDirective.java:677)
at sun.reflect.GeneratedMethodAccessor1025.invoke(Unknown Source)
InvalidLdapEntries.log
Task failed.
com.ptc.windchill.upgrade.updates.UpdateExecutionException: Error executing IncrementalUpdate Invalid Ldap Entries (#InvalidLdapEntries)
Nested exception is: (com.ptc.windchill.upgrade.updates.directives.directivesResource/39) com.ptc.windchill.upgrade.updates.DirectiveExecutionException: Method server code com.ptc.windchill.ldap.InvalidLdapEntriesDT.runDiagnostics failed. See nested exception for details
I think there is something wrong the conf branch in the LDAP. Look under the o=configuration, make sure you have the right entries for you search base under .LDAP, .EnterpriseLDAP adapters
Do you have all your jndi adapters initialized. The best way to identify this is by navigating to Participant Administration > Search for disconnected principals. If you see disconnected principals who are valid users, then ensure whether you have all your LDAPs are declared in wt.federation.org.directoryServices. If the disconnected principals are deleted users then, you need to reconnect to fix or delete the users.
Thanks for the reply Binesh.
I have deleted all the disconnected users and executed WinDU again, but still getting the same errors. LDAPs are also declared properly.
Your server is a clone of the production server?
Yes. Its test sever which is a copy of production server.
Maybe you have errors after the rehost process.
You changed the name of windchill host name?
I didn't get any errors after rehost. System is up and running fine but on running WinDU, these errors are coming up.
Could you send or attach the entire MS log from the startup?
Thanks a lot Binesh.
We have found some entries are missing in our test server LDAP. We re-imported Ldif from Production server.
Then, WinDU task Verifies the Internet Domain got completed successfully.
But still Invalid LDAP Entries task is failing.
