WinDU
RH_9609748
2-Explorer
WinDU
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS27
WinDU - Missing Master Discovery Tool found 4 entries and I like to know how to solve it.
I tried the actions in https://www.ptc.com/en/support/article/CS1847?source=search , but with no positive result.
Here are the errors that I faced
File MissingMaster.log
Mon 4/29/24 14:41:53: Discovered iteration(s) of class com.ptc.windchill.enterprise.data.EnterpriseData on wt.vc.ControlBranch:2807370 with missing Master object.
Mon 4/29/24 14:41:53: com.ptc.windchill.enterprise.data.EnterpriseData:2807371
Mon 4/29/24 14:41:53: Discovered iteration(s) of class com.ptc.windchill.enterprise.data.EnterpriseData on wt.vc.ControlBranch:2807905 with missing Master object.
Mon 4/29/24 14:41:53: com.ptc.windchill.enterprise.data.EnterpriseData:2807906
Mon 4/29/24 14:41:53: Discovered iteration(s) of class com.ptc.windchill.enterprise.data.EnterpriseData on wt.vc.ControlBranch:2807926 with missing Master object.
Mon 4/29/24 14:41:53: com.ptc.windchill.enterprise.data.EnterpriseData:2807927
Mon 4/29/24 14:41:53: Discovered iteration(s) of class com.ptc.windchill.enterprise.data.EnterpriseData on wt.vc.ControlBranch:2807948 with missing Master object.
Mon 4/29/24 14:41:53: com.ptc.windchill.enterprise.data.EnterpriseData:2807949
The MissingMaster.log file provides valuable information about the missing Master objects. Based on the log entries you’ve shared, it appears that there are missing Master objects associated with class com.ptc.windchill.enterprise.data.EnterpriseData on the wt.vc.ControlBranch. Sometimes, rebuilding indexes can resolve issues related to missing objects. Consider rebuilding the search indexes in Windchill. Verify the integrity of your Windchill database. Ensure that there are no inconsistencies or corruption. If you have any customizations or extensions, check if they impact the EnterpriseData objects.  If the issue persists, consider reaching out to PTC Support for further assistance.
