Planning on a late year upgrade from PDMLink 10.0 m040 to PDMLink 11.0 m010.
When I go into WinDu. the only upgrade option is: Windchill 10.0 to 10.2 Pre-Upgrade Mandatory.
Is there a new WinDu that needs to be installed on top of 10.0 m040 that will perform the mandatory checks for a PDMLink 11.0 upgrade?
I have installed the following patches for WinDu/WinRu after I upgraded to m040:
You better check the references on this web page, because PTC says my planned upgrade is supported.
http://support.ptc.com/WCMS/files/35412/en/WCSupportedUpgradePaths_42617.pdf
