I did an upgrade to Windchill PDM link 11.1 not too long ago. During the process of creating a staging area for the software, I created a Software CD Directory of installation media. Now that the upgrade has been completed for some time, In the interests of trying to increase available disc space, do I still need to keep this directory or can I delete them.
An example of the contents of this directory:
- Windchill 11.1 Common Base
- Windchill 11.1 Directory Server
- Windchill 11.1 Index Search
- Windchill 11.1 Service Pack M020
- Windchill PDMLink 11.1 F000
- Creo View 5.1 Adapters _F000_windows
- Creo View 5.1 Clients _F000_windows
Thank you.
They may be safely deleted.
I do keep mine on a network shared drive, in case I may need to reinstall for a rehost or something.
You may consider zipping the staging area, which will save some space, but not a lot.
Put the files on a USB drive, 11.0 is about 7GB for all of the files.
Thanks Ben!
Thanks Ben that worked!
