Windchill集群从AIX平台迁移到Linux平台,MethodServer启动时出错。
ptc-4148881
2014-10-17 14:42:13,815 INFO  [main] wt.pom.properties - wt.pom.batch.spec.tableExpressionThreshold=5
2014-10-17 14:42:13,816 INFO  [main] wt.pom.properties - wt.pom.batch.spec.useTableType=          true
2014-10-17 14:42:13,816 INFO  [main] wt.pom.properties - wt.pom.batch.spec.useColumnList=         true
2014-10-17 14:42:13,816 INFO  [main] wt.pom.properties - wt.pom.batch.retry.enable=               true
2014-10-17 14:42:13,816 INFO  [main] wt.pom.properties - wt.pom.batch.closePreparedStatement.threshold=-1
2014-10-17 14:42:13,817 INFO  [main] wt.pom.properties - wt.pom.batch.insert.chunkSize=           -1
2014-10-17 14:42:13,817 INFO  [main] wt.pom.properties - wt.pom.batch.update.chunkSize=           -1
2014-10-17 14:42:13,817 INFO  [main] wt.pom.properties - wt.pom.maxQueryRetryCount=               5
2014-10-17 14:42:13,817 INFO  [main] wt.pom.properties - wt.pom.oracle.disableAlwaysSemiJoin=     true
2014-10-17 14:42:13,818 INFO  [main] wt.pom.properties - wt.pom.oracle.blobInlineWriteThreshold=  -1
2014-10-17 14:42:13,818 INFO  [main] wt.pom.properties - wt.pom.emptyTableQueryClassChunkSize =   400
2014-10-17 14:42:13,818 INFO  [main] wt.pom.properties - Windchill DataStore: Oracle
2014-10-17 14:42:13,818 INFO  [main] wt.pom.properties - JDBC Driver Version: major=10 minor=2
2014-10-17 14:42:13,837 FATAL [main] wt.method.server - MethodServerMain abort
java.lang.NoSuchMethodError: wt.method.jmx.JmxConnectInfo.<init>(ILjava/lang/String;Ljava/lang/String;)V
        at wt.method.jmx.JmxConnectInfoHelper.createJvmConnectInfo(JmxConnectInfoHelper.java:103)
        at wt.method.jmx.Hook.<clinit>(Hook.java:33)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:169)
        at wt.method.MethodServerImpl.<clinit>(MethodServerImpl.java:128)
        at wt.method.MethodServerMain.run(MethodServerMain.java:351)
        at wt.method.MethodServerMain.start(MethodServerMain.java:263)
        at wt.method.MethodServerMain.main(MethodServerMain.java:207)
2014-10-17 14:42:13,839 FATAL [main] wt.method.server.shutdown - MethodServer stopped
经确认,wt.method.jmx.JmxConnectInfo这个类是存在的。
help!
jessh
(To:ptc-4148881)
Your JmxConnectInfoHelper class is clearly incorrect.  It is from 9.0 M080 or an even earlier release.
