Windchill 10.1 - Start windchill "headless"
aemaeth.2501
I am unable to start a windchill without having some xterm windows popping. Is that possible to run it without any display ?
Thanks !
Thibault Magné
jessh
(To:aemaeth.2501)
By default, yes, xterms come up (for easy troubleshooting if you have a
display).
But configuring not to do this is simple enough. See the documentation
for details.
On 2/21/2013 3:07 AM, Thibault Magné wrote:
> Hi,
> Thanks !
> Thibault Magné
I'll check the documentation deeper.
Thanks.
The help is greatly appreciated !
Thibault Magné
2013/2/21 Ponurski, Artur <artur.ponurski@meritor.com>
> Yes, first site.xconf change after out-of-the-box install of Windchill
> 10.1 on RHEL:****
> Since X window was used to perform the installation to start Windchill as
> process not as x term Add to site.xconf ****
> <property name="wt.manager.cmd.MethodServer" overridable="true"&lt;br"/>> targetFile="codebase/wt.properties"
> value="$(wt.manager.cmd.MethodServer.java.command)"/>
> <property name="wt.manager.cmd.ServerManager" overridable="true"&lt;br"/>> targetFile="codebase/wt.properties"
> value="$(wt.manager.cmd.ServerManager.java.command)"/>****
> Then propagate using xconfmanager –p****
> Regards,****
> Artur****
