Windchill 10.1 and Creo 2.0
canderson
Working on a migration plan from massive amounts of ProE data on many network drives to Windchill 10.1. Problem is when I locate a ProE object on the network drive and try to save it to my workspace I get an error "xxxxx.prt cannot be saved to the workspace"... but if I migrate to a different folder location open up a completely different object I am allowed to save that .prt to my workspace. Now if I go back to my original object xxxxx.prt I can save it to my workspace. This is repeatable.. my problem is for every object I want to save to my workspace I have to go through this ridiculous process.
10 REPLIES 10
Hi. Post log of all MethodServer and Creo.
? Sorry I don't follow you...?
Did you solve your problem? I´ve the same issue!
regards,
Martin
No I am waiting on PTC feedback... set up "Logging" today. ran through the excersice to reproduce the issue. All I need to do now is send info to PTC.....
tmcnaney
(To:canderson)
Hi Carl,
To make sure I understand...
You have a Creo 2.0 (datecode?) Parametric session with WC 10.1 (datecode?) registered as primary server with an active workspace. Then you browse to open a .prt from a network drive, and it retrieves into session fine. Next, you try to Save to the default location (which should now be the active WS), and it fails?
I am not able to reproduce this with Creo 2.0-M010 + PDMLink 10.1-M010.
What are your startup and set working directories?
It shouldn't matter, but do you have write access to the network share?
Have you tried starting Creo Parametric with no site-specific config.pro?
Have you tried to use the WS Tools > Import to Workspace?
Tom
Great to hear from you. To answer your questions..
Creo Parametric 2.0 M010 + PDMLink 10.1 M010
Startup directory is on a network drive.. .I have changed this to local same results. I have write access to the network drive.
I have tried with no Config.pro... still have the problem
Import to Workspace does work. I don't get the opportunity to fix Ghost objects or automate the Part Creation and Association.
It is strange. It won't let me save the file to my workspace but once I select a differnt object in a different folder and come back to the original it allows me to save...
tmcnaney
(To:canderson)
That is strange...let's see what TS comes back with after reviewing the logs.
I will lookup the Case # and follow-up with you next week.
Has something to do with dm_search_primary_server.. when turned off I don't have the problem.... Craig Pater is looking into this further... thanks for the support Thomas...
mhug
(To:canderson)
we had similar problems to checkin a drawing with creo2-M010 to wc10.1-M010 (all parts and assemblies from that drawing were checked in).
Then we installed creo2-M020 and the same drawing could be checked in .
