Someone has already done Windchill10 integration with Microsoft Active Directory, I did the same procedures used in version Windchill 9.1 and not work. I open case in PTC and has 4 months and nobody has solved the issue.
This issue is not integrate with Microsoft AD.
The build is F000 today I will update for M010 for check is I have a luck thai this working.
I can not imagine that around the world do not have any deployer that has made such integration.
Can't you treat the AD like any other ldap?
Create the ldap adapter. Create the repository for the adapter.
provider url: ldap://xxxxxx:port
user to connect with: cn=xyz,ou=abc
credentials: xyz
search base (where users are located): ou=users,dc=com,dc=xyz
search scope: subtree?
additional properties
| com.adldap.windchill.mapping.user.objectClass: | user |
| com.adldap.windchill.mapping.user.uid: | sAMAccountName |
| com.adldap.windchill.mapping.user.uniqueIdAttribute: | sAMAccountName |
| com.adldap.windchill.mapping.usersOrganizationName | xyz |
I do this. This is part of the procedure. Thanks!
Please try using attached approach. Very simple, robust.
Oops - It appears that you can't attach a file (am I missing how to do so??) - write to me directly if you like and I'll supply a PowerPointon how to do this.
Oops - It appears that you can't attach a file (am I missing how to do so??) - write to me directly if you like and I'll supply a PowerPointon how to do this. mike.lockwood@alconlabs.com
We have actually abandoned the approach posted previously - now working on a much more standard integration with our new corporate parent. Only complexity (which has been a major problem) is that some users were created long ago in EnterpriseLDAP branch of Aphelion.
So - My current advice is to ignore my previous postings and rely on PTC's approach to A/D integration..
