We just upgraded this weekend to 10.1 M040. All working pretty well except one major problem.
Executing aSearch usingthe Search field in the upper right (global search) returns either no data or bizarre results, usually with no CAD doc's returned but occasionally not returning WTRefDoc's either. Have had hours and hours of web sessions on this. Not repeatable. Have changed / reset related preferences many times. Have done multiple test upgrades on different servers - randomly seem to get this behavior.
We have SOLR indexing installed but have not done indexing and indexing new is not enabled. But - Setting the preferenceindex search = yes (sometimes only) fixes the problem. This should not be related so maybe it's just a ghost in there.
Urgent request: Until this is figured out we'd like to simply remove the Search field in the upper right and the related Types drop-down immediately to the left of it until this is figured out. That will force users to access Advanced Search via the navigator only. We're very familiar with using ActionModels to control this type of thing - but it seems that Search is not defined via ActionModels - must be some other method. PTC is working on how to do this via tech support case also.
For now we're handling by emailing all users with the instruction not to use global search.
This seems incredible to us - how can Search not work!!! Has anyone else seen this in 10.x?
thanks in advance
