Windchill 11.0 Classification Search missing
ClaudiuCraciun
I'm trying to follow Part Link training related to classification and I found that Classification is missing under Search.
I'm new in Winchill language.
Any Idea how to add the Classification?
Thank you for your help
CC
10 REPLIES 10
Maybe you don't have classified data or you don't have the PartsLink in your windchill installation.
In windchill 11 parts link search is integrated with the advanced search.
Please have a look at the documentation:
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=NewandChanged_ClassificationSearch&action=show
Riccardo
Integrated but must be installed
rvecchiato
(To:SergeyEfimov)
Yes, you are right, but I have seen from the screenshot that Claudiu was searching where it was the previous version of PartsLink
KD
(To:rvecchiato)
In addition based on the datecode of Windchill 11 you have to install the server component for Index Search Server to get the Classification Search in UI.
PTC has separated the client and server component for Index Search Server in Windchill 11 M010 I guess.
Kaushik
HI,
Bellow are the application installed, but the search classification still doesn't appears.
Am I doing something wrong for that the classification doesn't appears.
Thx,
CC
      F000      Creo 3.1          vizpviewrun.10.3.0.00.42       01         PTC Creo View - Clients
      F000      11.0                 pjl.11.0.0.00.455                     01         PTC Windchill ProjectLink 11.0
      F000      11.0                 whc.11.0.0.00.41                    02         PTC Windchill 11.0 Help Center
      F000      Creo 3.1          vizadapters.13.3.0.00.42       02         PTC Creo View - Adapters
      F000      11.0                 pdml.11.0.0.00.455                 01         PTC Windchill PDMLink 11.0
      F000      11.0                 solr.11.0.0.00.455                  01         PTC Windchill 11.0 Index Search
      F000      11.0                 ie.11.0.0.00.455                    01         PTC Windchill 11.0 Info*Engine
      F000      11.0                 wnc.11.0.0.00.455                   01         PTC Windchill 11.0 Services
      F000      11.0                 commonpdm.11.0.0.00.455   01         PTC Windchill 11.0 Common Base
      F000      11.0                 ptlc.11.0.0.00.455                  01         PTC Windchill PartsLink 11.0
Hello
be carrefull .  You're on 11 F00.
in 11 F00 , the Partslink classification search is not really integrated. Still the "old fashion" tree browser in addition to normal Advanced search (and need If i remember to be activated by pref or at least create a Classification tree before ....)
You need to be in 11 m020 to have the new features:
- Classif Search embeded in Advanced Search
-faceted results   etc ...
Need few steps in Windchill installation cause based on Index Search engine
regards
KD
(To:ClaudiuCraciun)
Please refer below article in PTC.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS245167
Kaushik
Hi
Please refer below article from PTC.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS247027
Naresh
Please try to add the following entry in codebase/config/actions/search-actionmodels.xml
  <model name="search page action">
        <action name="classificationSearch" type="search" shortcut="true"/>
    </model>
After addition of that entry, do 'reload actions' which is available under Customization(Tab) -> Tools.
(To enable customizations tab, got to Site->Utilities->Preference Management->Set Client Customization to YES)
Hope this helps you!
