Windchill 11.0 compatibility in Azure cloud
PS_9472314
6-Contributor
I want to use Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS11
Is windchill 11.0 supported on Azure cloud?
If it is supported , Can we use Azure sql database for installing Windchill.
I think all your questions are documented here:
https://www.ptc.com/en/support/article/CS381955?source=search
Its a Yes but...
  • Azure SQL Single database is the only configuration that is supported
  • Azure SQL Managed instance database is not supported
  • Azure SQL RTM is managed instance.
Its a Yes but...
Hello ,
We  are tried to install WC 11.0 in azure cloud , but we don't have any option to select cloud database instances.
Please refer the below screenshot and suggest.
Thanks.
BenLoosli
(To:PS_9472314)
My question is: Why are you trying to install a program that is 5+ years out of date. Windchill 13 is released.
My guess is that they are doing a cloud migration first, or at least moving the back end database.
