Hi all,
has anyone successfully installed Windchill 11.1 on Windows server 2016 with oracle 12c R2 without any error? I have been trying from past few days and been getting new errors everyday.
If you are facing deploy failed for ie with error code=1, then explicitly specify windchill JAVA path and continue the installation. Installation succeeds.
