Windchill 12c SendMail error
TJ_10505309
6-Contributor
Version: Windchill 12.0
Use Case: Every mail being set out from any user gets the following message in the queue entries Invalid substitution syntax, "[" missing, near line 107 of /windchill_home/Windchill/tasks/wt/mailSendMail.xml I have checked with Notepad ++ and cant find any miss matched brackets. This file has not been edited and is the original from the install. Is this a known bug?
Description:
Has this worked before then suddenly stopped working? Any system changes? Possible there are special characters in email addresses that are being processed? Just throwing out ideas since I could not find anything in knowledgebase.
Hi, fresh install, so it hasn't worked at all. I have thought about special chars being sent into the xml and have looked but we carefully selected our passwords for that very reason
