Version: Windchill 13.0
Use Case: A new Windchill customer is Spain has the following request: - Create Windows Servers for Windchill Apps in Amazon AWS - Create SQLServer instance in Azure The reason is economic
Description:
Any experience on this kind of scenario? Would you recomend it?
What should be taken into account in terms of performance and communication?
Thanks in advance!!
Article - "[Knowledge Hub] Windchill PLM - Cloud": https://www.ptc.com/en/support/article/CS252892
Hi @MaiteFarreny,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
