Hi All,
We are upgrading Windchill 8.0 M050 on Solaris 10
WSP installtion fails, error as below:
Error
Failure reading file:/opt/xxxx/windchill/codebase/WEB-INF/web.xml20090313094514: Connection timed out
javax.xml.transform.TransformerException: Failure reading file:/opt/xxxxx/windchill/codebase/WEB-INF/web.xml20090313094514
Also tried belowTAN, this resolves problemon WinXP but not on Solaris 10.
<u>https://www.ptc.com/appserver/cs/view/solution.jsp?n=140624</u>
Please suggest me if I need to do any more changes on Solaris 10.
Thank you in advanced,
Avinash
Hi Alexius,
Thanks for your help.
I already used this procedure. With this changes, On Win-XP I am able to installed properly without any error.
But on Solaris I did same chages but not able to succeed, I am facing same error.
Could you please let me know, ifyou areable to installed 8.0 M050 on Solaris??
Avinash
Hi Avinash,
Did you find any solution to this problem? I might find myself in the same situation next month as there is an upgrade to 8.0M050 planned and my server is on Solaris 10.
Arun
