Hello Experts,
I am in the process of upgrading my WIndchill 8 system.
During that, I am preparing a clone of the production system by doing a Rehost.
During the rehost, I am executing the following script from WIndchill shell to rehost the LDAP, and I am getting the error:
ant "-Dtarget-ldap=ldap://cn=manager:ldapadmin@hnjlptshri123.domainname/" -Dtarget-domain=hnjlptshri123.domainname
Getting the following error:
About to re-configure Info*Engine servlets in web.xml. Continue? (y,n)
[echo]
[echo] -- Re-configuring IE and RPC servlets in codebase/WEB-INF/web.xml --
[copy] Copying 1 file to D:\ptc80M50\Windchill_8.0\codebase\WEB-INF
[xslt] Processing D:\ptc80M50\Windchill_8.0\codebase\WEB-INF\web.xml to D:\ptc80M50\Windchill_8.0\codebase\WEB-INF\web_rhost.xml
[xslt] Loading stylesheet D:\ptc80M50\Windchill_8.0\bin\adminTools\rehost\xslt\updateIeServletParams.xsl
[xslt] : Fatal Error! Failure reading file:///D:/ptc80M50/Windchill_8.0/codebase/WEB-INF/web.xml Cause: java.net.ConnectException: Connection timed out: connect
[xslt] Failed to process D:\ptc80M50\Windchill_8.0\codebase\WEB-INF\web.xml
BUILD FAILED
D:\ptc80M50\Windchill_8.0\bin\adminTools\rehost\build.xml:144: Fatal error during transformation
at org.apache.tools.ant.taskdefs.XSLTProcess.process(XSLTProcess.java:506)
at org.apache.tools.ant.taskdefs.XSLTProcess.execute(XSLTProcess.java:209)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:269)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:301)
at org.apache.tools.ant.Target.performTasks(Target.java:328)
at org.apache.tools.ant.Project.executeTarget(Project.java:1219)
at org.apache.tools.ant.Project.executeTargets(Project.java:1067)
at org.apache.tools.ant.Main.runBuild(Main.java:632)
at org.apache.tools.ant.Main.startAnt(Main.java:183)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:197)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:56)
Caused by: Fatal error during transformation
at org.apache.tools.ant.taskdefs.optional.TraXLiaison.fatalError(TraXLiaison.java:349)
at com.icl.saxon.Controller.transform(Controller.java:963)
at org.apache.tools.ant.taskdefs.optional.TraXLiaison.transform(TraXLiaison.java:138)
at org.apache.tools.ant.taskdefs.XSLTProcess.process(XSLTProcess.java:495)
... 11 more
Caused by: javax.xml.transform.TransformerException: Failure reading file:///D:/ptc80M50/Windchill_8.0/codebase/WEB-INF/web.xml
at com.icl.saxon.om.Builder.build(Builder.java:267)
at com.icl.saxon.Controller.transform(Controller.java:936)
... 13 more
Caused by: java.net.ConnectException: Connection timed out: connect
Take a look at TAN 140624:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=/140624.htm
This TAN was writtent for an error during a service pack install, not a rehost. But it looks like the same error that you're running into. Try the steps from this TAN and see if that allows the rehost tool to complete sucecssfully.
