Hi @MS_10390550
There is a reason that the attributes are locked.
One of the reason could be calculation by relations in a Creo.
If you update the value in a Windchill, Creo will update it based on the relation.
So it is not good idea to change the value.
If you want to change PDM attributes in the Creo, then try to follow article: cs195124
allow_create_pdm_param to yes in config.pro allow you to change the WM parameters for new modes..
PetrH
Hi @MS_10390550
PetrH
