Windchill CAD structure
CS_10428158
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.16
Unable to build CAD structure to part structure. I'm missing some of the CAD components that should be showing in the CAD Part structure.
No error or warning. If I go to the missing components it and compare cad structure it gives me an error: "No related CAD document"
Article - "Windchill PDMLink: WTPart structure build failed because the related CAD Documents are unverified or not regenerated in the CAD tool": https://www.ptc.com/en/support/article/CS297988
From the CAD Document page in windchill, please do a "Actions > Compare to Part Structure". You can share the outcome with of course hiding any sensitive information.
Cheers
Hari
Hello CS_10428158,
Was the information provided helpful somehow ?
KR,
Charles.
Make sure that the CAD files are related to WTParts. Typically the CAD will be linked to the WTPart with an Owner link so that is will appear in the BOM.
