OK, Can someone please point me in the direction, or steps, or wherever i need to go, in order to get the display in Windchill, (commonspace, and workspace) to display a model parameter in the columns. currently it shows number, name, version, state, file name. "Name" is the ptc_common_name
I know how to create custom columns, and change the columns, and organize all of that.
I however, want to replace the "Name" columm, with a "description" column. The description is located in the model parameters under "DESCRIPTION"
The reason i dont want to use NAME (ptc_common_name) is because our BOM reports are pulling descriptions from the model parameters, and if that particular parameter isnt filled in, it shows blank in the BOM report.
(maybe there is a way to have the bom report pull ptc_common_name and it would be easier)
you have to have the parameters you want to see in windchill set to designate in parameters pop up.
I think you are asking about customized views in Windchill. Please follow below article.
