I have a couple of follow up questions on the Configuration Assistant recommendations...
When it suggests 2 Methodservers - does that mean 1 FG and 1 BG Methodserver?
When it suggests 3 Methodservers - does this mean 2xFG and 1 BG Methodserver?
Do you accept the wt.pom.querylimit recommendation of -1 (ie unlimited) as I am sure someone from PTC told me to set this at something like 75000 to prevent massive searches killing the machine?
Rgds
Gary
I have had a look at this and I can see a couple of Configuration Assistant parameters that need changing (at least on my system):
wt.pom.paging.snapshotQueryLimit - seems to be set to only 10000
The first will surely limit search results too drastically?
And the second prevents things like File Vault content verification working as the numbers of vault files in each folder is higher than 10000...
Also, when running it on my Test Server, where I previously had a FG MS with 3GB and a BG MS with a 1GB allocation, it changed this to one FG with 1.7GB and one BG with 1.7GB. My concern with this is that 1.7GB does not seem enough for a FG MS?
I appreciate this is only my Test Server but it is very representative of my Prod server and we had to increase the FG MS to 3GB to get it to stop crashing?
Any ideas on the better memory configuration?
Rgds
Gary
