Hello everybody,
in Creo Modeling, in the integration with Windchill, is it possible to define a softtype cad as in Creo Parametric?
What is the way?
Thank you,
Matteo.
in the meantime I found the solution that I report below:
Using EPMDefaultSoftType.EPMDefaultSoftType.xml
For detailed information on defining soft types, on selecting attributes
and about setting constraints, refer to the Windchill Help topics
Center related to the management of types and attributes. There is also a file,
EPMDefaultSoftType.xml, located in WT_HOME \ codebase \ com \ ptc \ windchill
\ uwgm \ aad \ xml, which can be copied to WT_HOME \ codebase. It's possible
modify the file copy to specify default soft types. To make effective
changes, the method server must be restarted.
