Windchill Customization(Giving constraint to an attribute)
SOLVED
Re: Windchill Customization(Giving constraint to an attribute)
Theresa I implement your solution It working fine as a multiselect thanks for that ..
But what I want is a littile different .
I need the functionality of MultiValued attribute like that plus or minus button
Thanks everyone for your answers finally I got the answer after backtracking the OOTB functionality.
I ve the same problem to resolve. Could you explain to me how you succeed to get a multi valuated component with suggested list? backtracking OOTB functionality? Tank's a lot. I am on the PDMLink 10.4.
Using this code has one demerit
The OOTB processor can’t persist the value so you have to write a custom processor also.
Hi Kaushik,
Thanks for sharing the code. Please share the processor src too. this will help a lot.
Thanks in Advance.
I assume that the IBA’s internal name is VendorName and it’s only in a specific subtype of WTDocument whose
internal name is com.ptc.Agenda.
For Create Mode :-
package ext.customization.processor;
import java.util.Arrays;
import java.util.Enumeration;
import java.util.HashSet;
import java.util.Iterator;
import java.util.List;
import javax.servlet.http.HttpServletRequest;
import wt.doc.WTDocument;
import wt.fc.ObjectReference;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.folder.Folder;
import wt.util.WTException;
import com.ptc.core.components.beans.ObjectBean;
import com.ptc.core.components.forms.FormResult;
import com.ptc.core.lwc.server.LWCNormalizedObject;
import com.ptc.core.meta.common.TypeIdentifierHelper;
import com.ptc.core.meta.common.UpdateOperationIdentifier;
import com.ptc.netmarkets.util.beans.NmCommandBean;
import com.ptc.windchill.enterprise.doc.forms.CreateDocFormProcessor;
import com.ptc.windchill.wp.delivery.DeliveryRecord;
public class CustomDocProcessor extends CreateDocFormProcessor
@SuppressWarnings({ "rawtypes", "unchecked" })
@Override
public FormResult postProcess(NmCommandBean paramNmCommandBean,
List<ObjectBean> paramList) throws WTException
/* Taking the object of WTDocument which is created form the CreateDocFromProcessor*/
WTDocument localWTDocument = null;
for (Iterator localIterator = paramList.iterator(); localIterator.hasNext(); )
localWTDocument = (WTDocument)(((ObjectBean)localIterator.next()).getObject());
try{ /* Checking whether the WTDocument is of desired subtype */
if(( TypeIdentifierHelper.getType(localWTDocument).toString().equals("WCTYPE|wt.doc.WTDocument|
com.ptc.Agenda ")))//internal name of your subtype
HttpServletRequest req = paramNmCommandBean.getRequest();
Enumeration em = req.getParameterNames();
String temp = null;
while(em.hasMoreElements())
String name="VendorName";//internal name of your iba
String old = "old";
temp = em.nextElement().toString();
if(temp.contains(name) && !temp.endsWith(old))
break;
//Giving value to the soft attribute
LWCNormalizedObject obj = new LWCNormalizedObject(localWTDocument,null,null,new
UpdateOperationIdentifier());
//removing duplicate value
obj.load("VendorName");
obj.set("VendorName",(String[])new HashSet( Arrays.asList( req.getParameterValues(temp) )
).toArray( new String[]{} ));
/*persisting the value of IBA after removing duplicate value*/
obj.apply();
PersistenceHelper.manager.modify(localWTDocument);
catch(WTException e)
e.printStackTrace();
// TODO Auto-generated method stub
return super.postProcess(paramNmCommandBean, paramList);
For Edit
import java.util.*;
import com.ptc.core.components.forms.EditWorkableFormProcessor;
public class CustomEditDocProcessor extends EditWorkableFormProcessor
@SuppressWarnings("rawtypes")
@Override
/* Taking the object of WTDocument which is created form the EditWorkableFormProcessor*/
try
if( (
TypeIdentifierHelper.getType(localWTDocument).toString().equals("WCTYPE|wt.doc.WTDocument|com.ITCINFOTECH.VendorPart")))
String temp = null;
String old = "old";
break;
@SuppressWarnings({ "unchecked" })
String[] s = (String[])new HashSet( Arrays.asList( req.getParameterValues(temp) ) ).toArray( new
String[]{} );
List<String> list = new ArrayList<String>();
for(String str : s)
if(str != null && str.length() > 0)
list.add(str);
s = list.toArray(new String[list.size()]);
/* After removing any blank string from String array */
obj.set("VendorName",s);
obj.apply();
Thanks And Regards,
Kaushik
Hi Kaushik,
Is there a way to fetch all the attributes for a given subtype?
Is there a way to pull the metadata of the fetched attribute?
For example, i have a subtype of "CustomerExperience" object and many attributes configured on this subtype.
I am trying to fetch all the MBA(Model Based Attributes) and IBA(Instances Based Attributes), and after that fetch all the constraints,default values, datatype etc.. i.e metadata of the attribute
RK
Hi RK,
To fetch all the IBA's of a given softtype use below method.
public static ArrayList<String> getIBAInformationForSoftType(
String internalName) {
ArrayList<String> logicalNames = new ArrayList<String>();
LogicalIdentifierFactory factory = new LogicalIdentifierFactory();
TypeIdentifier ti = factory.newWCTypeIdentifier(internalName);
GetSoftSchemaAttributesCommand command = new GetSoftSchemaAttributesCommand();
command.setType_id(ti);
try {
command = (GetSoftSchemaAttributesCommand) command.execute();
AttributeTypeIdentifierSet atis = command.getAttributes();
Iterator iter = atis.iterator();
while (iter.hasNext()) {
AttributeTypeIdentifier ati = (AttributeTypeIdentifier) iter
.next();
if (!ati.getAttributeName().equals("view")) {
try {
String name = ati.toLogicalForm();
logicalNames.add(name);
System.out.println("Logical identifier of the IBA :- " + name);
} catch (Exception e) {
} catch (CommandException e) {
return logicalNames;
Kaushik
Hi Kaushik,
Happy new year. Thanks you so much for repying.
I tried the snippet however it fetches only the IBAs. I am trying to fetch both IBAs and MBAs, i.e. all attributes(instance based and model based). Any furthur updates on all attributes is really helpful.
RK
Hello Ramakrishna,
Happy new year to you to.
For MBA try below snippet.
public static ArrayList<String> getIBAInformationForHardType(String className) {
ArrayList<String> attributes = new ArrayList<String>();
TypeIdentifier ti = factory.newWCTypeIdentifier(className);
GetHardSchemaAttributesCommand command = new GetHardSchemaAttributesCommand();
try {
command = (GetHardSchemaAttributesCommand) command.execute();
while(iter.hasNext()){
AttributeTypeIdentifier ati = (AttributeTypeIdentifier) iter.next();
if(!ati.getAttributeName().equals("view")){
String name = ati.getAttributeName();
System.out.println(name);
attributes.add(name);
return attributes;
getIBAInformationForHardType("wt.doc.WTDocument")
Thanks and Regards,
Kaushik
