I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.2
Windchill Desktop Integration is crashing the windows explorer after Windows 11 proposed update to:
Edition Windows 11 Pro
Version 22H2
OS build 22621.963
Experience Windows Feature Experience Pack 1000.22638.1000.0
System Type 64-bit operating system
the problem is due to Windchill’s 12.0 DTI lack of support for windows 11
the only release that supports windows 11 is windchill 12.1.1.0
proposed upgrade to that release
Hello CK_10374314,
I'm Charles from PTC Technical Support in Europe, may I suggest you open a new case for this issue?
I remain at your disposal for any questions or concerns.
Kind Regards,
Charles Gautier.
