I am doing an R&D on the Windchill ESI - TIBCO - ORACLE COnfigurations and Mapping. I found this article below:
https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/esi_install/ESIORACLEInstallConfig.html#
Mapping and configuration are precise, but I am not sure about the hardware Sizings, like
1. what OS is needed for Windchill ESI and TIBCO
2. What Java Version is required for Windchill ESI and TIBCO
Those answers are likely found in the software Matrix:
https://www.ptc.com/en/support/article/CS196783?source=search
Thanks, @avillanueva, that helped a lot.
