Windchill Error while loading the Describe By document using linked to MPMStandardOperation
HJ_10071856
8-Gravel
I am experiencing an error (as attached in the screenshot) when trying view the Document attached to the MPMStandardOperation on Windchill 11.1.
Furthermore, this is happening intermittently using a non-admin account only however this error is not appearing when logged into Windchill with an admin account.
Following is the snippet from the Method Server logs:
Resource bundle/Message key = wt.vc.config.configResource/1
(wt.vc.config.configResource/1) wt.vc.config.ConfigException: An element of the wt.fc.QueryResult"results" is invalid: all elements should be "wt.vc.views.ViewManageable"
Would appreciate any suggestion, how to overcome this issue.
8 REPLIES 8
Hi @HJ_10071856
Will you share the complete logs? Did you clear the cache first?
Hi @Rocket_Max, Yes I did cleared the browser cache (on the client machine) and also cleared the Apache Tomcat and Info Engine cache on the server. But no luck.
Following is the complete Stack Trace from one of the Method Server Logs while replicating the issue: have replaced the actual time stamp with "Date Time" and masked the username to ####
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: Message: Resource bundle/Message key = wt.vc.config.configResource/1
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: wt.vc.config.ViewConfigSpec.process(ViewConfigSpec.java:317)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: wt.part.WTPartStandardConfigSpec.process(WTPartStandardConfigSpec.java:367)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: wt.part.WTPartConfigSpec.process(WTPartConfigSpec.java:612)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.collectionsrv.engine.Query.processByConfigSpec(Query.java:1569)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.collectionsrv.engine.Query.execute(Query.java:912)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.collectionsrv.engine.CollectionSrvHelper.buildResult(CollectionSrvHelper.java:553)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.htmlcomp.collection.engine.UICollector.processCollectionDefinition(UICollector.java:4563)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.htmlcomp.collection.engine.UICollector.getDependents(UICollector.java:4131)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.htmlcomp.collection.engine.UICollector.collect(UICollector.java:1785)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.htmlcomp.collection.engine.StandardUICollectionService.collect(StandardUICollectionService.java:663)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.core.htmlcomp.collection.engine.StandardUICollectionService.collect(StandardUICollectionService.java:725)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: sun.reflect.GeneratedMethodAccessor1269.invoke(Unknown Source)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: java.lang.reflect.Method.invoke(Method.java:498)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.sun.proxy.$Proxy45.collect(Unknown Source)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.assocnav.server.CollectorServiceAssociationNavigator.performCollection(CollectorServiceAssociationNavigator.java:448)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.assocnav.server.CollectorServiceAssociationNavigator.navigate(CollectorServiceAssociationNavigator.java:192)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.assocnav.server.AssociationNavigatorHarness.expandTIIs(AssociationNavigatorHarness.java:186)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.assocnav.server.NodeExpander.expandAndSortIds(NodeExpander.java:453)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.assocnav.server.NodeExpander.expand(NodeExpander.java:233)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.ops.server.internal.NavigateOperation.run(NavigateOperation.java:223)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.ops.server.internal.NavigateOperation.runUsingAsyncDataSource(NavigateOperation.java:121)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.ops.server.DefaultOperationDispatcher$OperationServiceDataSourceTask._execute(DefaultOperationDispatcher.java:327)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.cat.ops.server.DefaultOperationDispatcher$OperationServiceDataSourceTask.run(DefaultOperationDispatcher.java:290)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.mvc.ds.server.DefaultDataSourceManager$DataSourceTaskCallable.callInContext(DefaultDataSourceManager.java:224)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.mvc.ds.server.DefaultDataSourceManager$DataSourceTaskCallable.callInContext(DefaultDataSourceManager.java:193)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: com.ptc.mvc.ds.server.MethodContextCallable.call(MethodContextCallable.java:47)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: java.util.concurrent.FutureTask.run(FutureTask.java:266)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.core.collectionsrv.engine.CollectorSrvCache #### - CollectionSrvHelper.getStackTrace :: java.lang.Thread.run(Thread.java:748)
Date Time ERROR [DataSource Task Executor-82976] com.ptc.cat.ops.server.internal.NavigateOperation #### - Message: Resource bundle/Message key = wt.vc.config.configResource/1
at wt.vc.config.ViewConfigSpec.process(ViewConfigSpec.java:317)
at wt.part.WTPartStandardConfigSpec.process(WTPartStandardConfigSpec.java:367)
at wt.part.WTPartConfigSpec.process(WTPartConfigSpec.java:612)
at com.ptc.core.collectionsrv.engine.Query.processByConfigSpec(Query.java:1569)
at com.ptc.core.collectionsrv.engine.Query.execute(Query.java:912)
at com.ptc.core.collectionsrv.engine.CollectionSrvHelper.buildResult(CollectionSrvHelper.java:553)
at com.ptc.core.htmlcomp.collection.engine.UICollector.processCollectionDefinition(UICollector.java:4563)
at com.ptc.core.htmlcomp.collection.engine.UICollector.getDependents(UICollector.java:4131)
at com.ptc.core.htmlcomp.collection.engine.UICollector.collect(UICollector.java:1785)
at com.ptc.core.htmlcomp.collection.engine.StandardUICollectionService.collect(StandardUICollectionService.java:663)
at com.ptc.core.htmlcomp.collection.engine.StandardUICollectionService.collect(StandardUICollectionService.java:725)
at sun.reflect.GeneratedMethodAccessor1269.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at com.sun.proxy.$Proxy45.collect(Unknown Source)
at com.ptc.cat.assocnav.server.CollectorServiceAssociationNavigator.performCollection(CollectorServiceAssociationNavigator.java:448)
at com.ptc.cat.assocnav.server.CollectorServiceAssociationNavigator.navigate(CollectorServiceAssociationNavigator.java:192)
at com.ptc.cat.assocnav.server.AssociationNavigatorHarness.expandTIIs(AssociationNavigatorHarness.java:186)
at com.ptc.cat.assocnav.server.NodeExpander.expandAndSortIds(NodeExpander.java:453)
at com.ptc.cat.assocnav.server.NodeExpander.expand(NodeExpander.java:233)
at com.ptc.cat.ops.server.internal.NavigateOperation.run(NavigateOperation.java:223)
at com.ptc.cat.ops.server.internal.NavigateOperation.runUsingAsyncDataSource(NavigateOperation.java:121)
at com.ptc.cat.ops.server.DefaultOperationDispatcher$OperationServiceDataSourceTask._execute(DefaultOperationDispatcher.java:327)
at com.ptc.cat.ops.server.DefaultOperationDispatcher$OperationServiceDataSourceTask.run(DefaultOperationDispatcher.java:290)
at com.ptc.mvc.ds.server.DefaultDataSourceManager$DataSourceTaskCallable.callInContext(DefaultDataSourceManager.java:224)
at com.ptc.mvc.ds.server.DefaultDataSourceManager$DataSourceTaskCallable.callInContext(DefaultDataSourceManager.java:193)
at com.ptc.mvc.ds.server.MethodContextCallable.call(MethodContextCallable.java:47)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
HelesicPetr
(To:HJ_10071856)
Hi @HJ_10071856
Try to add a full control ACL rule for WTObject to the user.
If the error disappears then you need to find a specific object type where the ACL rule is missing
(do not forget to delete participant cache after ACL change) HelesicPetr_0-1697631967614.png
PetrH
thanks @HelesicPetr. I will give it a go.
Regards
HelesicPetr
(To:HJ_10071856)
Hi @HJ_10071856
the error
says that some query that is returned in some table or place on the page, has wrong object
for example there is Master Object instead of specific Iteration because user do not have a access to the object.
This can case that error
You need to find what object is the specific one that cases the troubles 😄
PetrH
Hi @HJ_10071856
There are no additional clues in the logs. I suggest you open a case for Technical Support to track.
This issue requires debugging to analyze. At the same time, I have also found many similar SPRs in the knowledge base.
If possible, you can also check if the issue is fixed by installing the latest CPS
HelesicPetr
(To:HJ_10071856)
Hi @HJ_10071856
If the admin does not see the error, then ACL rules are missing for the users
MethodServer log can show more detail of the error.
PetrH
Hi @HelesicPetr, yes that is true. Admin user are supposed to have Full Control whereas the intention is that the non-admin user should only have Read access. However the actual problem is encountered when loading the page, wherein no attempt is made to modify/add information to the Standard Operation or the linked Describe By Document.
Following is the stack trace from the Method Server logs when I tried to replicate the issue: have replaced the actual time stamp with "Date Time" and masked the username to ####
